BMW 316 m40 problem
11 years 2 months before #47521 by manual-mecanica
Problem with BMW 316 M40. Posted by manual-mecanica
The temperature rises very quickly to the halfway mark but doesn't go any higher. I've cleaned the radiator, which was clogged, but it's still the same. The thermostat and temperature sensor are fine. Does anyone know what the problem is?
The cylinder head has also been tested.
11 years 2 months before #47523 by manual-mecanica
Manual-mechanics response on the topic of problems with BMW 316 M40
Urgent help SOS! My temperature rises very quickly to the halfway mark but won't go any higher. I've already cleaned the radiator, bled it properly, and replaced the thermostat and the radiator temperature sensor, but it's still the same.
11 years 2 months before #47524 by manual-mecanica
Good afternoon, you need to check the engine's water pump or recirculation pump.
11 years 2 months before #47525 by manual-mecanica
Thanks for replying. Well, let me tell you, the cylinder head was resurfaced 0.5mm, new water pump, new viscous fan, new temperature sensor, new thermostat, the radiator was cleaned, and it's still the same.
11 years 2 months before #47528 by manual-mecanica
I suppose it goes up until the thermostat opens if you want to know if that is the problem annuls the thermostat provisionally then puts and tesacaras the doubt
