Good problem with 2kd ignition
11 years 2 months before #47497 by manual-mecanica
Hello friends, I'm having problems with a Toyota 2KD. There's no pulse reaching the injectors. I've already tested the ECU in another truck and it works fine. I've also tested the crankshaft sensor, camshaft sensor, and rail pressure sensor, and they all work in the other truck. I've checked the wiring and it's all good; none are broken. The fuel pump and injectors were tested at a lab and are working fine. And just to be thorough, I've checked all the fuses and they're all good.
11 years 2 months before #47506 by manual-mecanica
Manual-mechanics response on the topic: Hello Friends, Problem with 2kd ignition
Look if by chance wears a contactor of inertia or collision and rearm it or it is a thing of anti -theft immobilizer, because for what you say you have already looked almost everything ... this right!
