Hi everyone, I need some help. I recently replaced the fuel pump on my Clio 1.5 dCi because the old one was checked at Bosch and they said it wasn't delivering enough fuel. The car was stalling while driving, idling poorly, and the engine was misfiring terribly. So, I decided to replace it using the timing tools. With the new pump in place, I manually bled the system until fuel came out of the nuts holding the injector lines. I tried to crank the engine, and it turns over perfectly, but the darn thing won't start. Does anyone know what the problem could be? It would start with the old pump, even if it was running rough. THANK YOU IN ADVANCE.
