Mazda BT 50 Diesel does not pass the 100 km/h
11 years 1 month before #47275 by manual-mecanica
Mazda BT 50 Diesel does not pass the 100 km/h published by Manual-Mecanica
Nesto helps, I have a Mazda BT 50 diesel that does not pass the 100 km/hy on the climbs and blacks black.
11 years 1 month before #47278 by manual-mecanica
Hi Osvaldo.
It is likely that there is restriction in the feed air inlet, check the filter.
Miguel
11 years 1 month before #47287 by manual-mecanica
Thanks for answering soon. The truth is that I reviewed the complete admission system to the reinforcement pressure of Turbo 6 PSI. In high RPM Turbo Control Solenoid vgt.ok. EGR OK OK admission sensor OK.
11 years 1 month before #47288 by manual-mecanica
Hello everyone, those pick up, like many Mazda in general do not have a check -up light or light ... therefore and seeing that it has been reviewed as probable .... I recommend scanning the truck, it can have one or more problems of control of the injection, if the scanner comes out OK, that is zero failure, Checkea distribution, compression and/or a possible obstruction in the exhaust system. Good luck and greetings.
