Mercedes spronte the oil level rises
11 years 1 month before #46815 by manual-mecanica
The oil level rises from one day to another the engine is well but smokes with raw oil smell when it takes temperature
11 years 1 month before #46816 by manual-mecanica
Manual-Mecanica response on the Mercedes Spronte theme the oil level rises
Hello Javmor.
You probably have excessive fuel pass in one or several cylinders due to injectors or pressure regulating valve, check that and verify compression pressure. The smoke should be black or dark gray and the smell is fuel without burning.
LUCK
MIGUEL
