MEGANE2 K9K ALTERNATOR FAILURE
11 years 5 months before #46302 by manual-mecanica
MEGAN2 K9K ALTERNATOR FAILURE PUBLISHED BY MANUAL-MECANICA
OLA Canimecos,
I have a problem with the megane 2 1.5DCI alternator, do not load how strange hehe, someone knows if this model is cut from the alternator ?????, and where is this ????? If anyone has the electrical scheme of the Electric Food System I would solve the terea to find out very much
thank you very much
11 years 5 months before #46305 by manual-mecanica
Manual-mecanica response on the topic megane2 k9k alternator
Hello Aarbo, this carries 2 types of alternator, Bosch 150 A, or Valeo 110 A. In the two it has a built -in regulator (which will have to check the brushes of these, the good tightening of the diode bridge. Generally the regulator goes on the back cover of these. If you want to try it, the hot values ​​(15 min. Of operation are enough) are:
1000 rpm = 57; 20000 rpm RPM = 105
