Astra 2.0 Model 2008
11 years 8 months before #45982 by manual-mecanica
Astra 2.0 model 2008. Published by manual-mecanica
Hello, I would like the electrical manual for the Astra 2.0. I need to know how to turn off the check engine light because a P0130 fault code cannot be cleared, and the client wants to sell the car and avoid spending more money on spark plugs, wires, coils, and the oxygen sensor. Thank you in advance.
11 years 8 months before #45983 by manual-mecanica
Manual-mechanics response on the topic of the Astra 2.0 model 2008
Hi palomoynaty, if it's leaking air in the catalytic converter/manifold line, the sensor will continue to show a fault. A faulty sensor plug or wiring will also cause a fault. Also, check for any false air leaks in the intake (manifold gaskets). If checking these things doesn't fix the problem, and disconnecting the battery for 15 minutes doesn't help, some people resort to "taking the easy way out," as they say... tampering with the instrument cluster and disconnecting the check engine light... but this is not at all honest, nor is it what a mechanic should do. However, if you don't have any more money to spend, or any other resources, this is your choice. The best thing to do is check these points, and the fault should disappear on its own once the problem is fixed. Keep in mind that if the fault is with the ECU, it could end up costing more than the car itself. Cheers!
