CITROEN C3 CONDITIONED AR
11 years 8 months before #45396 by manual-mecanica
Aricado Citroen C3 published by Manual-Mecanica
Boa Noite, these days appears um c3 that Não Armava or understanding ac verifique e havia gas no system of conditioning mild Entao Em um colleague that tinha tracker and ele discs have defend I do not defend the perigo perigo system ao massa elimininei or curto e nao voltou to work verifies and nao fusivel be fusive.
11 years 8 months before #45404 by manual-mecanica
Manual-Mecanica response conditioned subject
Hi Eder, check compressor clutch (continuity). Greetings!!
11 years 8 months before #45448 by manual-mecanica
Ja install or understanding of the veículo em on outro e normally operated; hair seen or defends e na bsi ouvi dizer that there is a procedural procedure to Ativar Saida de Power of Bsi that is blocked so nao sei as Faz will be souber something appreciated.
11 years 8 months before #45456 by manual-mecanica
Hi Eder, you must test on the road for 5 min in "automatic" mode to 21º left/21ºDech to start the system. (This is after connecting battery again) Greetings !!
11 years 8 months before #45462 by manual-mecanica
BOA NOITE, PASSEI This veículus em um scanner lexia and elevatou curto ao massa dai intão fiz or repaired mais a saída of power of bsi found is blocked ouvi dizer that theme um procedure to attempt to the power of power of Bs seems to open a bind hold that theme uma does not know how to order to the preceding, obrigated pela attenção.
