The word error appears ,,,
11 years 10 months before #45367 by manual-mecanica
The word ERROR appears... Published by manual-mecanica
I have a problem with a 2007 Chevy Malibu with a 2.2 engine. It parked normally, and when they tried to start it, it wouldn't start. It does absolutely nothing... like you're trying to start it in reverse. The dashboard lights come on, and the odometer illuminates, but after about three seconds, the odometer disappears and the word "ERROR" appears. It won't crank. If I try to start it directly with the starter motor, it cranks but doesn't start, and there's no spark at the spark plugs, even with the key in the ignition. The fuse box has already been checked. Thanks for any help.
11 years 10 months before #45368 by manual-mecanica
Manual-mechanics response on the topic: the word ERROR appears...
Hi Dayton Rodriguez, you should take it in for a diagnostic check. It could be anything from the crankshaft position sensor to a problem with the electronic immobilizer, so it's difficult to determine the cause at first glance. Good luck!
11 years 10 months before #45475 by manual-mecanica
Thank you very much for your answers ,,,, I am to give that and any thing I tell you ,,,,,,,
