Change Epic bomb for Bosch in Ford Transit
11 years 8 months before #45303 by manual-mecanica
Change Epic Bosch for Bosch in Ford Transit published by Manual-Mecanica
Hello, I would like to get in touch with someone to make this type of transformations because I have vast problems with a transit of 97 2.5TD that there is no way to start.
11 years 8 months before #45304 by manual-mecanica
Manual-Mecanica Answer on the topic change Epic bomb by Bosch in Ford Transit
Hi Raul40, if you comment that you have proven, they can help you, because the pump change can involve changing wiring, injectors, pump support ...
11 years 8 months before #45307 by manual-mecanica
Well in principle the bomb that the transit brings is a Lucas Epic and I have already mounted a Bosch compatible mechanics. In principle that I know the cable deck of the old pump they are annulled and only one of the pins of the deck has been used to give current to the stop valve. Now I am looked at with the entire accelerator system, putting the cable and new accelerator. We have also got Gasoil to the injectors but does not want to start. My biggest doubt is whether the cable deck that stays annulled, something must be done to deceive the switchboard in principle that I know not but I am not sure. The injectors have also proven them in bank and work and are consistent for this pump.
11 years 8 months before #45310 by manual-mecanica
Have you proven the pump draft on the engine? Because the static draft of one and the other may be different, it may be giving you problems for this at start, then there is the injector tarado, this pump may work to other pressures ...
11 years 8 months before #45311 by manual-mecanica
As for the cables, I would put a positive (with a switch) direct to the Pare Valve, to ensure that constant current comes, since you say it is completely mechanical by the Bosch, lest it is failing the electrical feed in this pare valve, by some subject of what you say about the cable mallet and the Ecu ...
