Skoda Octavia does not accelerate
11 years 10 months before #45197 by manual-mecanica
Skoda Octavia does not accelerate published by Manual-Mecanica
My Skoda 1.8 Gasoline Mechanical Box turns perfect but does not accelerate if you upholler the air entry if it accelerates perfect.
already change acceleration body gasoline pump.
CKP, MAF disassembled the electrical installation on the engine side rectified it completely turned perfect but not accelerates.
wings 1250 rpm is blocked is as if drowning
11 years 10 months before #45198 by manual-mecanica
Manual-Mecanica response on the Skoda Octavia theme does not accelerate
You must have an air intake or the castle admission collector or with some fissure, because it is not normal that if it "caps" accelerates well, see that you are not entering air through the purge hose (canister)
11 years 10 months before #45199 by manual-mecanica
Not at all just try a bit of plugging it the admission is tight already reviewed it
11 years 10 months before #45204 by manual-mecanica
I do not know if it carries a collector pressure sensor (MAP) is 1.8T I think that if it has an acceleration sensor on the pedal, if you have already looked at this, I think of anything other than the air input reading is badly (the MAP or MAF wiring thing ...) Continuity review in the plugs of these to ECU (by ruling out connection failure of any cable) or problem of the MAP itself) or problem of the MAP itself) If I had the slowdown, I don't think this is. You should make a diagnosis
11 years 10 months before #45247 by manual-mecanica
Thank you for your intention,
the computer cables were already checked tomorrow, Friday at the time of the afternoon they scan it and I will put the result the MAF was placed new the acceleration body was changed to that of another car that works well the temperature sensor changed by a new one the admission is disarmed all and of correcting any good questions there is tomorrow I continue again thank you again thank you again
