My Skoda drown
11 years 9 months before #44776 by manual-mecanica
My skoda published by Manual-Mecanica
Greetings Forer@s:
Yes, my Skoda Fabia drowned in a garage that entered rainwater and although I could remove it in time, the water reached the seats. The problem is that the airbag light remains on, so the ITV does not happen to me. Take it to the workshop and put it in the machine gave the failure of the airbag switchboard. I want to get a second hand (the original is above 500 lereles) and set up myself, but I do not know where it is located and if you put one of the same reference in good condition I will solve the problem. Nor do I find any workshop manual or electrical scheme of the car, can you help me?
Thank you so much
11 years 9 months before #44777 by manual-mecanica
Manual-Mecanica Answer on the subject my skoda drowned
Hello, if you put a switchboard, you may have to "reprogram" and ting tingla ... just to this, nothing, you should disconnect battery, and "blow" the connections in case there were moisture still ... Then if you carry any shock sensor, reactivate or dry it well, because any derivation may be giving the failure, I will tell you as a guide way that you lower any manual of seat cordoba or tole. less of the same time (they usually carry the same systems) to find the location and process of the airbag. If I find something I put it. Greetings!!
11 years 9 months before - 11 years 9 months before #44779 by manual-mecanica
Hello everyone, I add to what SR ismael expresses to reprogram, since the Air Bag switches in that car communicate in Red via Can, therefore if you extract or change it you must reprogram with a vag (scanner), if you arrive and put it most likely it is that this is blocked electronic. The location of the switchboards are located in the same Air Bag, passenger or companion, or others, are changed in conjunction with the Air Bag Unit. The electronic diagnosis was made by a serious person? Because I join what ismael53 says, in the sense that it can be moisture, do you include a fuse that has left, in contact of a positive with water ... Finally the diagnosis indicates you in both modules? driver and companion. I used for the Scoda in the Air Bag part this doc, how bad it is in English users.atw.hu/mulder82/download/caroserie.pdf. Here many diagnosis characteristics of the airbag and component location are described. Greetings and luck.
Last edition: 11 years 9 months before by .
