Chryler/Dodge Neon 1Gen Sohc 170+ Whp Mods
11 years 10 months before #44428 by manual-mecanica
Chryler/Dodge Neon 1Gen Sohc 170+ Whp Mods Published by Manual-Mecanica
Hello colleagues, my topic is referring to the neon 1Gen, if someone has one or armed with a 2.0l sohc engine that exceeds 170 whp without using turbo and that the car is not just [to run on track, I would like to know what is recommended to overcome these numbers
11 years 10 months before #44435 by manual-mecanica
Manual-Mecanica Answer on the Chryler/Dodge Neon 1Gen SOHC 170+ Whp Mods
Hello JC88, so that a 2.0 engine takes those horses, I will tell you how little I know, in case you want to take it: it would be complicated, but easier (relatively, if you have appropriate sewers, etc.) but atmospheric: you can only get through rpm increase, but for this it requires the increase in the entry of more mixture, also helping with a slight increase in compression, and so that RPM, (in addition to lightening masses), it will have to be shortened to change from change, (replace the conic group) and a long etc ... well, the fact is that in reality, when an engine is enhanced based on the crossroads of valves in sceso, the reality is that it becomes inconducible in the city, (at least with those 170cv in Atmospheric Just make a "repro" and 4 more things as the "commercial tuning" say, if not, I don't know what the Crisler engineers paint or any other. It limits a lot if you want to be reliable the "preparation", think about it, because to overcome those numbers that you say, there is no other than I know ... but this is just my opinion and I do not intend to discourage you, you continue investigating, there is much to know .. encouragement and luck !!!
11 years 10 months before #44440 by manual-mecanica
Hello, I do not know in your country to be used to correct in the streets here in Miami that type of car or engine is not used at all only the same car is used but with the 2.4 turbo or srt4. It is a very small engine and not of so much quality to support that work regime to be able to achieve that you will have to modify the engine completely. Good if you told me about a Honda Vtec there if I would recommend some things to upload the HP and you could use it for the newspaper and to run in the streets without any problem. Noo is to discourage you I love those lucky projects
