I need help please !!!!!!!
11 years 8 months before #44387 by manual-mecanica
I need help please !!!!!!! Posted by manual-mecanica
Hello, I have a problem with the direction of an Opel Vectra C GTS and I do not find the failure or find the workshop manual, I also have a Hyundai Lantra Wagon of the 99 that already begins to give a little the can of everywhere and if I could get the workshop manual it would be of great help because I have only ehncontrado the previous model, to see if you can make me a hand to get them.
11 years 8 months before #44391 by manual-mecanica
Manual-Mecanica Answer on the subject I need help please !!!!!!!
Hi Robertoroma, if you describe us more or less that happens to the address, we can help you among all. As for the manuals, I have none of these, if there is luck, any of all, may have it. greetings!
11 years 8 months before #44400 by manual-mecanica
Hi Ismael, the first thing to thank your answer thanks, in the direction of the Opel a slightly weird case happens to me and that when I turn left sometimes it sounds as if it lacked liquid and the direction is tough and at the moment it becomes well again, the case that I have looked at the level of the liquid of the address and the level is correct, I have been watching and I do not notice any loss of liquid by any side, apart from that fault, apart from that fault, apart from that fault. An invisible water leak because I do not find it anywhere, I deduce that it can be the water pump since it only loses water when it is torn and stains the area above the gearbox and I would like to know how I can see if the fault is of the pump and how to change it in case it is the pump since this car does not have distribution but it does not have a chain and I have never touched an engine with chain, so those are my doubts. You can help me, thanks.
11 years 8 months before #44402 by manual-mecanica
Hello, then I imagined it ... I have a caliber of 92 and made a penalty of everything, one of the things was the same symptom as you, I thought about changing the address box, because I thought it could be wrong in the cast valve or some calibrated step obstructed ... the fact is that I leave it for the last one and what I did was change the direction liquid and .. it seems that the problem is cleaned. Conclusion: A lot of shit and lack of liquid, after 7 owners that you have had ... Try to change it, it is the cheapest. It carries normal dexrom. greetings!!
11 years 8 months before #44403 by manual-mecanica
Olivide about the water pump: if the ceramic retain is broken, always loses (both cold and hot) by the axis of this, get under the car and look through the distribution area. Logically, it loses more with the engine running; If you would not see leaks, go thinking about the Board of Curate that this fried. I can advise you more or less that you lower the manual of the DTH motor vertra that is available on this page, it goes with chain and it can help you to guide you more or less. Greetings
