Injection pump
11 years 10 months before #44378 by manual-mecanica
Injection pump published by manual-mecanica
I have an injection pump of Izusu KB Turbo Diesel Year 2000, it turns out that it does not inject any diesel, the cutting solenoid is working well, and does not inject anything, which may be the problem ?????
11 years 10 months before #44379 by manual-mecanica
Manual-Mecanica Response On the Injection Pump
Hi Jamoza, I don't know if I will carry another electria transfer pump in deposit (make sure) and see if it works. If not, you have any air intake in the aspiration-bomb aspiration pipe, which prevents the diesel from reaching the pump, as it returns to behind. It may also be that you need to purge the air that the pump has opening the injector hills and turning the engine until the "fuel" comes out; after tightening, try the start to see .. greetings
