Electric Problem Corsa Evolution or Corsa C
11 years 10 months before #44350 by manual-mecanica
Manual-Mecanica Response on the topic Electrical Problem Corsa Evolution or Corsa C
Hello again nuancer! You have to confirm how many legs the relay has ... Normally if it is of lights it carries 4 or 5 legs (30, 85, 86, 87/87a).
Due to the problem you describe, or the unit of comfort fails or you lack a positive in the fuse box ...
first of all, check all the fuses of the box, lest there are any molten feeding.
11 years 10 months before #44352 by manual-mecanica
Hello partner, look at the reverse is 4 legs and 20 AMP. I already solve the radio and heating problem insert the codes and turned everything right. Check all the fuses and nothing even measured these to make sure and everything is fine but now I only have the lights.
11 years 10 months before #44353 by manual-mecanica
Hello! If it is 4 legs in the fuse box you must check:
in a terminal there must be +12V when putting the contact.
In another +12v when acting light command.
In another negative current.
With this we ensure that the correct food reaches the relay.
Care 100% that does not take current to the bulb and if you don't see it clear, try a new bulb. Greetings.
11 years 10 months before #44355 by manual-mecanica
I already fix the casualties now all the front parking lot, disconnect the lights and connect them as is and take out the relief and I arrived current from nowhere: Laugh: as, but they were fixed, I only have the parking lot, I will do what you tell me with the parking lot thanks for every partner!
11 years 10 months before #44356 by manual-mecanica
You are welcome!! When you know something you inform me! Greetings
