Electric Problem Corsa Evolution or Corsa C
12 years 5 days before #44332 by manual-mecanica
Electric Problem Corsa Evolution or Corsa C Published by Manual-Mecanica
The alternator failed and I consumed the battery, repair it and now load well, but the lights do not turn me on the radio or the heating would appreciate your help
12 years 4 days before #44338 by manual-mecanica
Manual-Mecanica Response on the topic Electrical Problem Corsa Evolution or Corsa C
Hi Maticoco! I imagine that you will have reviewed the fuses of the vehicle that is not molten ... If so, I would choose to check with a test lamp if positive current comes to the bulb connector. I await your answer ....
12 years 4 days before #44344 by manual-mecanica
Hi Angelcomouto I do not get current, the low lights carry a reliable and fuses are fine, disconnect the battery negative for a few minutes and now I turn on the light on the left side the others not, intermittent is fine and rear too but still I am missing the others that light and the radio and heating, as I check if the relay is good? Thank you for your help
12 years 4 days before #44345 by manual-mecanica
12 years 4 days before #44346 by manual-mecanica
Number 19 is a relay
