intermittencies do not work
11 years 10 months before #44286 by manual-mecanica
The intermittences published by Manual-Mecanica
Hello everyone, having if someone can help me, I have a Fiat Doblo 1.9 that the intention of the intention sounds, but the lights does not work, or with the normal command, or with that of the doubles.
Thanks in advance.
11 years 10 months before #44295 by manual-mecanica
Manual-Mecanica response on the subject does not work intermittencies
Try to clean the pineapple where the reverse is placed.
I think the reverse works but a strain of the relief is sulfate and does not send a sign. That or you have a cut of a cable and the lights do not receive a sign.
11 years 10 months before #44304 by manual-mecanica
Change the flash that is the problem, tell us how you are doing, greetings. :)
11 years 10 months before #44308 by manual-mecanica
Hello friend, what is the command of lights because in my path something similar is to jump a tooth i does not go the same piece can be governed
