Laguna gets hot chingon
11 years 10 months before #44184 by manual-mecanica
Laguna gets hot chingon published by Manual-Mecanica
Hello everyone, a 1.8 16V lagoon is working here that works correctly, but when you stop hot, after a while you try to start it and it is stuck: or it says that it does not start and starts to move the needles in a reset mode, or start and start and lower from 1000 to 2000, if it accelerates it does not pass from 2000rpm. (It is already in emergency mode), disconnect battery and you again bend and ... nothing has happened here, it works as if nothing. In the Renault they say that caudalimetro and switchboard, and I tell them: o The one, or the other ... do not cucane me. Let's see if you know something about the subject here, because those want to deceive me, instead of telling me they don't know. Thanks in advance
