Michel Banki turbines
11 years 11 months before #43820 by manual-mecanica
Michel Banki turbines posted by Manual-Mecanica
I am doing research about this type of hydraulic turbine I would help me a lot of information and/or contributions about this topic thanks can be by this means or through my email
11 years 11 months before #43836 by manual-mecanica
Manual-Mecanica Answer on the topic Michel Banki turbines
Hello aki you have all the practical iMformacion.org/michell-banki-urbine-urbina-michell-Banki
I do not understand much of the subject but I think that the town mill works the same and it has been working for more than 500 years: P
11 years 11 months before #43853 by manual-mecanica
Thanks my dear friend and well the basic principle of a hydraulic turbine is to transform hydraulic energy (waterfall force, flows etc) into mechanical energy that is generated by generating for generation of electric power from there. Its names of hydroelectric plants My main objective is the study and improvement of the Michel Banki turbine Power ...
continue uploading information that at the end of the process will give them my research to beeficio of anyone who needs it atte percy Ruiz
11 years 11 months before #43858 by manual-mecanica
I already read a little about that and it is only a transverse flow turbine design that due to its simple and facilitation design its efficiency is lower compared to others but by its flat efficiency curve it gives a long -term performance higher than other similar ones. This simplifying means that by its design allows the variation of efficiency with load to be less than other equivalents, giving a greater long -term performance and is frequently used for autonomous production without the presence of operators. In this link you will find the design and manufacture of a banki turbine. ri.ues.edu.sv/1786/1/dise%C3%91o_y_fabri...na_turbina_banki.pdf
11 years 11 months before #43881 by manual-mecanica
Thank you for your contribution, my dear friend and if your application is right, it is very useful since it provides very good long -term yields and does not need operators in addition to its maintenance is minimal and easy to implement but above all very economical what I am developing is an improvement of the design as in the algorithm of the same ..
