Skoda Fabia air conditioning
12 years 1 month before #43264 by manual-mecanica
SKODA FABIA AIR CONDITIONING PUBLISHED BY MANUAL-MECANICA
Hello
you will see ... I have a Skoda Fabia 1.4 gasoline.
The air conditioning gas is recharged recently, the button works, the car goes up for revolutions when I give the button (at 1000 +-) ... So far everything normal.
But neither does the A/A fan jump nor cools anything ...
I think it does not come to the compressor ... but I am not sure ..
someone can give me light in this matter ...
Thank you very much in advance, greetings !!
12 years 1 month before #43296 by manual-mecanica
Manual-Mecanica Response Skoda Fabia Air Conditioning Theme
Hello.
Check the following: 1. Disconnect the compressor electroembrage terminal and with a tester (OHM position) measures the strength of the clutch coil: if it is more than 4 ohm - you can carefully connect by means Ohm do not connect it, it may be crossed (short-circuited or burned)
2. In the installation connector that goes to the electroembrague connects a 12 V 3-5 watt bulb with a longer cable away from mobile elements (straps, ventilator etc) the car starts and starts the AA if there is no signal that the current arrives checks the fuse of AA (AC clutch) and the rel.
