Hydraulic direction
12 years 1 month before #42956 by manual-mecanica
Hydraulic address published by Manual-Mecanica
Good afternoon, I have a Renault Clio Model 98, I wanted to know if someone can give me a hand with the power of the hydraulic pump since it does not work for me and when measuring with the car in progress it does not reach tension.
Greetings.
Xavier.
12 years 1 month before #42971 by manual-mecanica
Manual-Mecanica Response on the topic Hydraulic Directorate
Good:
If you do not arrive current, it is most likely that the relay that feeds that electrical sector is burn (art. 7700810396). It is a relay (global violet color) of 50 AMP. You are applied in the fusera that is in the engine, next to the battery.
If that is not the problem, it may have been burned with the electric motor of the pump (it is something very common, although the repair is not cheap- from its own experience ...-).
Luck!
12 years 1 month before #42976 by manual-mecanica
Bárbaro, thanks for the answer I will review it and I see how it is doing.
Greetings.
Xavier
12 years 1 month before #43169 by manual-mecanica
Javier may be that I burn the relay that feeds. If that is not, the carbon of the electric motor were gaped, it is easy to change them, it is a common engine, do not pay on repair prices. The engine has 4 common coals, you take them out and purchases in any house of spare parts. In the back you have a bronze bushing that is spent, it is also achieved, it is fan, you will have to take to turn to the measure and forward it has a bearing that comes out no more than $ 25, 6203z if I remember correctly. I did noi less than 4 times, for $ 100, and nothing else is broken. They have asked me for more than $ 1500 to repair, and it is very easy to do it. Anything I have a guide with photos and steps to send you, look at the same bomb as the kangoo. Let me know.
Greetings
