MY FIAT TYPE VEHICLE FAVES YOGAGA
12 years 3 months before #42533 by manual-mecanica
Manual-Mecanica Answer on the subject MY FIAT VEHICLE TYPE 1994
Thank you and I also put the lid tomorrow, the uncovering and verifies Mucgas thanks for the information
12 years 3 months before #42534 by manual-mecanica
Friend the spark plugs and changed as 2 times since it has the fault because they get enchumb according to xq passes a lot of gasoline, the carburetor does not think it is because when he wants this serene in the minimum but the problem is when I climb up to the smallest now and boot explosions by the exhaust tube and I could not find solution
12 years 2 months before #42624 by manual-mecanica
Ahoga is drowning carburetor float level, perforated float
12 years 2 months before #42630 by manual-mecanica
Of course I then believe that changing the Kid to the carburetor should take that problem, I also do not know if it will be because the compression x is voting a little the downspout of the exhaust tube
12 years 2 months before #42690 by manual-mecanica
I believe that yes, change the joints and the carburetor needle, all in a kit,
with respect to the leakage for the exhaust if it is on the side of the collectors' together you have to change it is very important, and the base of the carburetor that is also
lucky
