2.5 diesel engine distribution strap
12 years 5 months before #41747 by manual-mecanica
2.5 Diesel Motor Distribution Correa Published by Manual-Mecanica
I have changed the distribution strap of my Ford Ranger 2.5 Diesel 2011, but the point and part was corrected but it gets and works as a tractor. I have tried everything but I don't know what else to do, I have made the chewing up but it is still the same
help please be craised.
12 years 5 months before #41751 by manual-mecanica
Manual-Mecanica response on the topic of distribution strap 2.5 diesel engine
What kind of smoke? Black --- White
you changed or broke the distribution strap,.,.,.
I await an answer
greetings from Peru:)
12 years 5 months before #41766 by manual-mecanica
:( I change it to mileage, but it is useless.
Only so that the 2.5 Diesel engine of Ford Ranger year 2011 is an information, a tooth cannot be passed since it catches valves instantly.
Mia Quebro 2 rockers.
Thanks for the help anyway.
12 years 5 months before #41769 by manual-mecanica
Little error ,,,,:( :( if you are going to fix it, disassemble the entire engine and check the connection of the connecting rods, they are very likely bent.
Greetings from Peru
12 years 5 months before #41772 by manual-mecanica
Friend, first of all once you place the entire distribution, it is convenient with a key to turn about 2 or 3 laps the engine from the crankshaft just to make sure that there has been a footprint that is very likely that it was that that happened to you.
