Help with transmission strap 1987 1.8
12 years 5 months before #41581 by manual-mecanica
1.8 MENCANICA TRANSMITION
Hello Nestito, it helps with the distribution strap of my Chevrolet Monza 1987 1.8 since they were cut some teeth buy a new one and I cannot put it since the car already named does not have a tensioner is all fixed the water pump both the gear of the camshaft and the one that is behind the damper I need urgent help, I will appreciate them
12 years 5 months before #41584 by manual-mecanica
Manual-Mecanica response on the subject Help with MONZA TRANSMITION 1987 1.8 1.8
The time strap can be tensioning the water pump and turning it, I hope this detail serves you.
12 years 5 months before #41586 by manual-mecanica
14982CA wrote: The time strap can be tensioning the water pump and turning it, I hope this detail serves you.
Thank you, I realize it so let the water pump but I do not turn to take it out and I could not if there is any special way to remove it, it would be appreciated thanks for your help
12 years 5 months before #41626 by manual-mecanica
I know what you are talking about
. recommend
you . By Lantanto he continues to throw the neck strap so strong as to move the crankshaft then take it to the gear or toothed wheel. Without placing it by compartment if not rather present it by supporting the tooth 3/4 parts of the width of the belt, do not worry to put it completely because you will not be able to with your strength, do not force it with levers that you can break it.
5. Now with a suitable dice and bar the crankshaft nut (below) turn to the side of the camshaft to put, ask someone to help you move the crankshaft while you avoid that the strap from the cam select time turns with the dice always down to completely accommodate the belt on the teeth of camshaft.
I hope it helps you, try to explain my best.
blessings.
12 years 5 months before #41627 by manual-mecanica
Hello
I know what you are
talking about . By Lantanto he continues to throw the neck strap so strong as to move the crankshaft then take it to the gear or toothed wheel. Without placing it by compartment if not rather present it by supporting the tooth 3/4 parts of the width of the belt, do not worry to put it completely because you will not be able to with your strength, do not force it with levers that you can break it.
blessings.
A MILLON THANKS MEN VERY CLEAR YOUR EXPLANATION I MAKE VERY CLEAR I WILL MA
