Diesel motor pound Izuzu C223
12 years 5 months before #41500 by manual-mecanica
C223 Motor Pub
Which can be the most likely cause of this sound.
12 years 5 months before #41506 by manual-mecanica
Manual-Mecanica response on the topic Diesel Izuzu C223 motor
Hi Guillermo_Felipe.
If you have black smoke and the pounding is deaf (like wood to wood), it is most likely to be injection, it would be necessary to look for injector by injector with the machine minimum to identify which is the bad. If the blow is like metal to wood and the oil pressure is low, it would be necessary to look for bench caps, in that case you would have dark gray smoke. If the blow is metallic the damage can be by valve or valve seat, the smoke would be white. I hope the data is useful. LUCK
MIGUEL
