It does not work 2 ° Cylinder
12 years 5 months before #41430 by manual-mecanica
It does not work 2 ° cylinder published by Manual-Mecanica
I have a Nissan V16 Red cover 1995 ...... The problem is that the second cylinder is not
working
... Someone can help me, I don't know what to do ......
12 years 5 months before #41445 by manual-mecanica
Manual-Mecanica response on the subject does not work 2 ° cylinder
Have you proven if you get tension to the injection?
12 years 5 months before #41446 by manual-mecanica
Yes, if it comes .....
12 years 5 months before #41447 by manual-mecanica
12 years 5 months before #41456 by manual-mecanica
You say that fuel does not reach the cylinder but you also say that the injector is good, and you already tried tension, and the spark, it would be necessary to try the injector pulses and measure or weigh the compression of the cylinder, I hope I have helped you, good luck.
