URGENT HELP PEUGEOT 206 NO ARRANCE
12 years 6 months before #41031 by manual-mecanica
URGENT HELP PEUGEOT 206 NO ARRANCE PUBLISHED BY MANUAL-MECANICA
Good day .... friends days ago I post the problem of a Peugeot 206, who does not start they told me to go where someone who encodes it, it turns out that the locksmith asked me for a code that I touch that buying in spite of that could not be corrected and now in the agency they say that it is not read that the key is put! what I do?
12 years 6 months before #41065 by manual-mecanica
Manual-Mecanica Answer on the subject Urgent Help Peugeot 206 No Arronze
Brother you have to ask in the agency to restart the original chip module. I explain that type of cars brings a unique internal chip that works when you put the key to the ignition of milliseconds compare the chip code that has the key that you introduced with the code that has the module or ECU of the car, if these coincide magic the car turns on ... blah blah blah ..... The question is that for some reason the chip of your key is distrustful, what you should do, what you should do, what you should do, what you should do, what you should do, what you should do, what you should do, what you should do, what you should do, what you should Synchronize your key with the ECU of the car ... That pod I do not believe much in the concessuals those panas sometimes do not find the fault ... I recommend a good place where they encode keys with chip, (eye not any locksmith because those who are the ones that decode the key), and I tell you it is not much the evil that is encoded in about 20 minutes but it is something expensive ... in the same way luck and I wait for you.
