Peugeot 206 on the pique loses output response
12 years 6 months before #41004 by manual-mecanica
Peugeot 206 on the pique loses output response published by Manual-Mecanica
Hello Nesty, it helps with the Peugeot 206 loses power in the pique (when you want to revashed like a cascade and this is done by seconds then reacts) the accelerator is sensor does not bring accelerator cable, which was washed the manager eliminating moisture of oil, clean the body of the accelerator sensor, clean the escape FAP, gasoline pump, gasoline pump brand 55lbs, with all this does not I manage to improve some idea in advance thanks.
12 years 6 months before #41168 by manual-mecanica
Manual-Mecanica response on the Peugeot 206 topic on the pique loses output response
Hello, I want to share that I manage to solve the problem, after doing several tests, the most difficult is to do without the light of activated witness. What was it was to change fuel filter, air filter, spark plugs, to all this it did not solve the problem yet until we detected a small spark brico in cylinder 3 it turns out that the coil was damaged the jumping was minimal that in ocations it is not noticed. Find a fact it turns out that this type of coil Biene to last 80,000km the vehicle exceeds 96,000km coil new problem solved.
