Again my Hyundai Matrix 1.5crdi does not start
12 years 7 months before - 12 years 7 months before #40900 by manual-mecanica
Again my Hyundai Matrix 1.5crdi does not start published by Manual-Mecanica
Hello, if someone can help me, I would appreciate it.
He was circulating and stopped and does not start, if you pushed him, but with the key no, I have tried the return of the injectors and they are fine, the computer does not give any breakdown, which can happen to him?. thank you. greetings.
Latest edition: 12 years 7 months before by .
12 years 6 months before #40966 by manual-mecanica
Manual-Mecanica response on the subject again my Hyundai Matrix 1.5crdi does not start
The position sensor tends to fail and without indicating any type of fault I happened to me with a matrix led him to scan to the hyundai and nothing changes this position sensor and the corduroy is over is not so expensive
12 years 6 months before #40967 by manual-mecanica
I had one with that fault in the workshop and it was low compression, Midala must be about 300psi
12 years 6 months before #40968 by manual-mecanica
It can be something as simple as an obstructed oil filter, take it out and fix it if it has dirt, if so, put it and test it, XK in this system the filter also works as a low fuel pressure regulator.
12 years 6 months before #41091 by manual-mecanica
Good morning, I am new on this page, so I present myself. I have an Hyundai Matrix 1.5 CRDI 180,000 kilometers and since June 2012 it began not to start from time to time, you could spend 15 days perfectly and at 16 suddenly it did not start, but in the middle hour it gave it the contact and started normal.
In Gamboa Motor (which is possibly the chorizos in Spain) they told me that I had to rectify 3 injectors and change the diesel pump, because according to them it is where the computer failure gave (this is impossible since the machine only detects sensors does not fail within the pump, or of the injectors). I have cleaned injectors and rectified one that was wrong in Sansan workshops in Madrid (which is possibly the best firefighter and also a very good price) and the car is much better (softer, less consumption, etc ...) although it warned me that this was not the failure so it does not start occasionally, after the month of the month "plas" again fails.
In Almoauto workshops they put the machine again and they have shown me that the failure is in the € 80 € camshaft sensor and in the € 120 crankshaft sensor (Hyundai already uses Hyundai with the prices of spare parts).
After many headaches this has been the solution, changing them after a month no failure.
Therefore, what I recommend to the people who have this failure is that for injection failures and bombing workshops Sansan in San Diego Avda (some monsters), for diagnosis Official Almoauty Workshop on Alcalá Street, very good treatment and professionalism.
Never gamboa that are sausages.
