Honda Accord 92, UREGE Repair it
12 years 7 months before #40827 by manual-mecanica
Honda Accord 92, UREGE repair it published by Manual-Mecanica
Hello friends of mechanics manuals, I need help since my sling is failing, the question is as follows:
By accelerating my car has a failure since it feels that it loses strength and even hears that Petardea, I no longer know what to do since I have made some repairs and does not improve.
Among the repairs that I have made: change of spark plug cables, change of distributor lid, change of valve cover packaging and injector cleaning, as well as oil change and filter service.
They will be appreciated if anyone knows what to do to correct this problem.
12 years 7 months before #40850 by manual-mecanica
Manual-Mecanica Response on the Honda Accord 92, UREGE repair it
Hello friend, you would have to check if the catalyst is not covered. If you have time for use, you can cover the exhaust gases output in an abrupt way and generate that your non-rpm rpm engine, if the engine has normal slowdown and only fails in high regime, observe that.
12 years 7 months before #40893 by manual-mecanica
It is a good suggestion I will follow your advice and I will check the catalyst since the car is already 20 years of use, thanks and since I review that I tell you what happened
12 years 7 months before #40894 by manual-mecanica
Another possibility is that the ignition time is varied, whether in the belt or in the distributor, another cause can be the exesive coal formation in the compression chambers, this is solved by putting a good amount of extra gasoline at least on one occasion, then you can use regular gasoline
