Mitsubishi Montero Sport Manual Nesecito Year 98
12 years 10 months before #40451 by manual-mecanica
Someone can facilitate Mitsubishi Montero Sport workshop manual of 98 V6 3.0 if possible in Spanish.
And also know how the fuel pump disconnect, if you have any relevable or fucible to stop working. Thank you already.
12 years 10 months before #40453 by manual-mecanica
Every vehicle with electronic system has a fuel pump opening and fucible pump which would be the specific question to disassemble the com pump. o Find problem in the electrical system
12 years 9 months before #40505 by manual-mecanica
Thanks Job, but I need to know the hubication of the reoy or the fuse. To disconnect the pump. Fuel. For a few minutes, since my car also has an alternative fuel that is CNG and it seems to me that while I am with CNG, a fuel injector is licking. Then before disarming all the injectors to control them I would like to do that test, to disconnect the pump so that it does not flow more fuel through the ramp of imjectors. Although they are electrically disconnected, when following the pump sending a naphtha pressure, a licor could be produced, I explain myself ....
