Ford does not start
12 years 10 months before #40419 by manual-mecanica
Ford does not start published by Manual-Mecanica
Greetings to all those of the forum ... I was born a help with my Ford Berlinda ... year 80 ... JUST THE ENGINE AND RECTIFY COLATA After assembling the engine does not start and everything is in order has the spark plugs, also fuel, distribution height, starts but as if it were out of advance, despite being correct ... if they can help you appreciate them ... for FAVA ...
12 years 10 months before #40423 by manual-mecanica
Manual-Mecanica response on the Ford subject does not start
I tell you that model I do not know, but as normal by turning a little that of the coat we fan or delay the explosion, but it is the use of a strovescopic gun (I do not remember is a gun that gives light flickers) in the clutch mass or in the crankshaft pulley you will see a mark that adjusts with that.
12 years 10 months before #40434 by manual-mecanica
First you must penetrate the crankshaft to the degrees of advance, then you put a spark plug in the cylinder nº1 and toured the of theco until the spark jumps. You will be ready to the point of theco
12 years 10 months before #40439 by manual-mecanica
Thank you, I'm going to try with the sticoscopics ... and I tell you ...
12 years 10 months before #40440 by manual-mecanica
I'm going to penetrate the crankshaft and that of theco .... Good to disarm ..... we are in contact ...
