Daewo Nubira coil does not generate spark at exit 2y3
12 years 8 months before #40337 by manual-mecanica
He was changed by DIS
12 years 8 months before #40358 by manual-mecanica
Manual-Mecanica Answer on the topic Daewo Nubira Bobina does not generate spark at exit 2y3
This bad is the bovine package 2 and 3, the wiring is cut or the ECU this bad.
Because the STD does not work: that the sensor is bad, that the connector has a problem, the relay that activates the electro is not reaching the computer signal, or the ECM is with a problem.
