Antifreeze in tsuru lll oil
12 years 8 months before #40330 by manual-mecanica
Antifreeze in tsuru lll oil published by manual-mecanica
Auto Tsuru 2006 The antifreeze to the oil was passed and 5 months ago the head board the fault it presents is that when removing the cap from the cold radiator and full of antifreeze when the engine the engine the antifreeze is empty to the carter does not boil like when the head of the head is damaged, it will be the distribution cover or that something else can be thanks greetings.
12 years 8 months before #40342 by manual-mecanica
Manual-Mecanica response on the antifreeze theme in Tsuru Lll oil
And already replaced the board ??
12 years 8 months before #40345 by manual-mecanica
Most likely to have the burned joint
