Failure with the cold engine
12 years 6 months before #39956 by manual-mecanica
Failure with the cold engine published by Manual-Mecanica
Hello, I have a Peugeot 306 90 CV TD, which has a few days failing in cold,
I spliced, I let the light of the heaters be extinguished and start perfectly but the engine heads and made white smoke, when the engine is hot no longer does, the air and gas filter are new, verified heater are fine, that it can fail.
thank you
12 years 6 months before #39987 by manual-mecanica
Manual-Mecanica response on the subject fails with cold engine
Can you have an injector failure, I made a diagnosis to see what error code shows you?
12 years 6 months before #39996 by manual-mecanica
Hello, this Peugeot 306 TD 90 CV car is from 1998, it is PSA engine, it has no center to make diagnosis,
today I have changed the gassoil filter again, it seems that the failure does less but it does, and it also does it hot, I do not know if to remove the injectors and take them to check them That I have solved it can make me a hand.
thank you
12 years 6 months before #40016 by manual-mecanica
What injection pump class does?
12 years 6 months before #40017 by manual-mecanica
Place the complete car data, the more information the help will be
