How to try the oxygen sensor
12 years 7 months before #39810 by manual-mecanica
How to test the oxygen sensor published by Manual-Mecanica
Hello friends of this forum I have a volswagen goal that the oxygen sensor this evil tells me the mechanic because I started the fuel ...... and as I can try the sensor it is 4 cables .....
12 years 7 months before #39811 by manual-mecanica
Manual-Mecanica response on the subject how to test the oxygen sensor
You click on the black cable of the four that have two targets and the gray with a polyymore has to range the tension between 0.50 and 0.900 MV. Changing the value more less every second according to the accelerate and the vehicle hot.
But I would begin to disconnect the battery for a few minutes and provaria to see how the corrects of the correct COs are given below 0.30 and Landa below 1030.
or buy what you spend.
12 years 7 months before #39827 by manual-mecanica
Ok friend will I try to try that way
the black color is signal ??? What has to oscillate right ???
