Corsa 1.4 Model 2002 vehicle failure
12 years 11 months before #38871 by manual-mecanica
VEHICLE FAULT CORSA 1.4 Model 2002 Published by Manual-Mecanica
I have a Corsa 1.4 Model 2002 vehicle, the vehicle presented a slight failure in low revolutions, the previous week the vehicle was stopped, lost completely power, change spark plug wires, spark plugs and coil, and the vehicle reacted well, until today, the same failure was presented, there were explosions and the vehicle was stopped again, I turn on for a second and I need to know if it is the fuel pump, someone can help to replace the OQ pump I must check in advance a very pleasant thanks
12 years 10 months before #38978 by manual-mecanica
Manual-Mecanica Response on the topic Failure of the Corsa 1.4 Model 2002 Model
Hello friend, it can be a problem of fuel pump, filters, etc. The right thing is that you make it scan to see which fault code throws you and act accordingly, tell us how you go, greetings. :)
12 years 10 months before #38999 by manual-mecanica
Thanks I already did and the vehicle Kedo very well
