Antiniebla Scenic lights do not work
12 years 11 months before #38835 by manual-mecanica
Antiniebla Scenic lights do not work published by Manual-Mecanica
Hi, the Renault Scenic 1.9 anti -flesh lights do not look, I have proven lamps and fuses are fine, the witness of the board also looks, I do not know if it takes any relay or where, do you know where I can find the failure?
All the best.
12 years 11 months before #38896 by manual-mecanica
Manual-Mecanica response on the topic Antiniebla Scenic do not work
You have check the switch, or if there is any loose or bad land, or if the contacts are dirty or if they are loose. The relays normally carry them by the engine or if not by the glove compartment.
12 years 10 months before #38905 by manual-mecanica
Hello, I have proven, wiring continuity from the EPU to the headlights and 4 relays two twins, and two others that are under it, but without knowing or what they are for, I have opened the EPU and nothing is observed that has produced spark Weakly, perhaps the black cable is mass, but not with the engine, now I will check the control taking advantage of the fact that I am installing a momentary momentary installation I want to feed the relay (Borne 86) with the positive of the crossing light. However, I do not want this to be the solution, the car installation is intact until it is able to solve the problem. Thanks and greetings
