Lamda probe
12 years 11 months before #38773 by manual-mecanica
LAMDA probe published by Manual-Mecanica
Hello good I would like to disconnect the lambda probe to buy this, since the car consumes me about 24 liters at 100 in urban, a varvarity, with loss of power, the engine goes like three cylinders. He heard that the arness that goes to the computer can be disconnected and Provar. 2000.I.8V Motor F3R B56C. This harness that is on the computer? Thank you very much, I wait for your answer.
12 years 11 months before #38774 by manual-mecanica
Manual-Mecanica Answer on the topic Lamda
I do not know if that engine is with cable and coils together, as is the clio, but that is the problem that the clio present, that the coils are broken, they change them and the problem ends and as you say, it seems that it was only an electrical problem and with coil, verify the cables if it is with cables and if it is with coils for each cylinder.
12 years 11 months before #38775 by manual-mecanica
I ccre that the coil is well arrives current at 4 spark plugs. This engine only has 1 coil for the four spark plugs. What I don't know if the current that reaches spark plugs is the one that has to have
12 years 11 months before #38810 by manual-mecanica
Measure the resistance of the cable. Nodebe having more
than 10 kilo ohm then also the resistance of the rotor and distributor cover if it has it.
