Toyata Hilux 2KD-FTV2494 Kun 2.5 L
12 years 11 months before - 12 years 11 months before #38765 by manual-mecanica
Toyata Hilux 2KD-FTV2494 Kun 2.5 L published by Manual-Mecanica
How can I erase the lux after changing the belt to this car and the di -filter light
  • Latest edition: 12 years 11 months before by .
    12 years 11 months before #38780 by manual-mecanica
    Manual-Mecanica response on the automotive topic Toyata Hilux 2KD-FTV2494 Kun 2.5 L
    To restart the T -Belt it is the following:
    - Turn the ignition key to on
    - press the ODO/TRIP button and leave it in odo, then return the ignition
    key to off
    - keep pressing the ODO/TRIP 5 second button
    - The number 15 appears on the digital odometer
    And for the filter light it should be sufficient to drain it because if it is on it is by the presence of water and if when draining it you do not turn off the light you must change the entire full portfilter with everything and its electrical sensor.
