RENAULT LAGUNA 97 CLIMATIZIZER
12 years 11 months before #38757 by manual-mecanica
Manual-Mecanica Response on the heating theme Renault Laguna 97
What are you calling the turbine motorcycle that is in the evaporator? Because it must be connected in series with resistances that also go in the same evaporator enclosure to cool with the same air flow and these resistances are responsible for the speeds of the turbine.
12 years 11 months before #38762 by manual-mecanica
Of course Mauro, they call it like that in the manuals to differentiate them from the electrventillars. This car has no resistance because the speed is regulated by digital control, that is, the air conditioner. The fan has the 12 volts but with that it only does not go, you have to send the tension that regulates the turns that gives the turbound as you say. From the control comes a cable that goes to the engine but not in this model 97 since model 96 brings changes in the board.
