RENAULT LAGUNA 97 CLIMATIZIZER
12 years 9 months before #38709 by manual-mecanica
RENAULT LAGUNA 97 CLIMATOR PUBLISHED BY MANUAL-MECANIC
The problem is the motorcyclector who does not despite having the 12 volts. The engine tried it in another lagoon and works, it seems that the tension that regulates the turns in the leg B5 does not reach. According to a manual of the 96 model there is a direct connection of the control to the engine, but in this model it is not like that. That is why I need the manual corresponding to the model 97 that comes with compu Motor. Thank you
12 years 9 months before #38710 by manual-mecanica
Manual-Mecanica Response on the heating theme Renault Laguna 97
Hello, it must be more specific to the car data, displacement, engine class, if it has heater or air conditioning, if it has an electro -ventilator or two.
In short, the relays begins to review because it depends on the first speed (series connection and works at 6V) or in the second speed (parallel connection and works at 12V).
12 years 9 months before #38711 by manual-mecanica
Thanks Mauro, the lagoon has a volvo 16 V motor two electroventillars and has a digital air conditioner. The glove compartment is the relay that feeds the engine and works, two positive cables arrive and two negatives to the motorcyclector, but as it is electronic it needs the tension that varies the speed, according Return from the motorcycle machine and nothing, in the 14 -legged card. I already stopped working and the few days arranged alone. The only one that discovered the rifle, a very fat white cable that prescales the tab and qx what I mediate, it goes to mass. I clean it but there was no change. The relay of the rifle exchanges them and remains the same.
12 years 9 months before #38734 by manual-mecanica
Hello, according to my self -dema scheme that car brings 3 relaxes for the operation of the electrventillars, it does not tell me its location but they almost always go close to the electro -ventilator attached to the front of the front next to the radiator. Check them to see if there is luck.
12 years 9 months before #38756 by manual-mecanica
Hi Mauro, check the 3 relay and walk, now I have a doubt, I am talking about the motorcycle maker, not the electro -seasons, what is not the ventilation and the heating neither the heating nor the air conditioning that starts and short.
