Cutting Electrovalvula Failure
13 years 2 months before #37861 by manual-mecanica
Cut Electrovalvula failure published by Manual-Mecanica
Hello, I have a Ford Transit with a Bosch pump, and when you take the contact the engine continues to turn. I think it is a failure in the supply electrovalve
13 years 2 months before #37936 by manual-mecanica
Manual-Mecanica response on the subject of cutting electrovalve
Hello, what kind of bomb do you have, is it Common Rail system?
If you can give me this information or better the number of the pump that is on a plate in the pump that are 10 numbers I can help you.
