does not look time or kilometers in the picture
13 years 2 months before #37633 by manual-mecanica
Hi, the time and odometer aren't working on the instrument cluster of my 2002 Nissan Almera Tino 2.2. Do you know why this might be? The speedometer and tachometer are working, though. And how can I fix it?
Thanks
13 years 2 months before #37637 by manual-mecanica
Instrument clusters have several bulbs, and like any bulb, they can burn out. If the bulb for the odometer display has burned out, you won't be able to see anything. You have to remove the cluster and replace the bulb located directly behind the odometer.
13 years 2 months before #37651 by manual-mecanica
Thanks, and do you know if it's very difficult for a beginner like me? Or if special tools are needed?
13 years 2 months before #37701 by manual-mecanica
They do not usually need special tools. You have to be careful when correctly disassembling so as not to break any piece of plastic. Look for the manual or seek well if there is some hidden screw
