Rover 620 SDI (2.0 Diesel) Injection problems?
13 years 3 weeks before #37595 by manual-mecanica
Good afternoon.
I have a 620 SDI rover, as it appears in the matter, and it takes a while that I slowly slow down, an irregular idle, not always but often does it, underway the chivato of the engine sometimes turns on and the engine stops, but when going running, it works again, and if it stops alone, there is no way to start it with the key, it has to be pushing it, it has to be pushed. That being the problem of the injection pump, a retention valve behind the diesel filter was put, but it is still in it, I do not know what to do it to the rover, official concessionaire or what to do with it, but whenever I use it and if I go only above all, "pray" so that it does not stop.
I hope someone can help me or give their opinion.
Thank you so much. All the best.
13 years 3 weeks before #37609 by manual-mecanica
Manual-Mecanica response on the ROVER 620 SDI (2.0 diesel) injection problems?
I do not know if you have looked at the pressure pump that you have on the deposit, if you do not keep the flow rate, it is ups and for the motor collector to look.
13 years 3 weeks before #37611 by manual-mecanica
Ola looks at that Rover 620 SDI vehicle has a problem when it has spent several years of use and it is very simple to solve, the injection pump has a file with many cables, if a cable is cut or makes false contact you can cause you that fault as easy is to bridge with small cable stretches that file you are peeling one by one and it will be the welds approximately about 10 cables with a little lucky. It helps you after you let me know me if I am well I'm going to study your problem to see if it can be something else luck byby
13 years 3 weeks before #37631 by manual-mecanica
Thank you very much, I will look at that option, since as you can see I have given me two answers ...
When I solve it I will say here that it has happened ...
13 years 3 weeks before #37632 by manual-mecanica
Thank you very much, it may be that it is from the bomb, since also the sneak is turned on as comment, for that I will take it to the workshop, saying what you have told me, when I solve it I tell you.
All the best.
