Gentlemen I need help me, maybe one of you know and recommend that doing, seeing I am not an expert on the contrary I am learning and I liked this pod of the mecànica, for such reason I will detail the entire incident to help me detect what the problem can be:
1.- Friday: Cai in tremendous hole bursts the two right tires
2. Minutes of driving the car, I start feeling a small failure, just as it was of spark plugs, but the spark plugs just changed them do not have a month and have worked very well, they are a dense mark.
3.- All week I felt that little failure.
4.- The Sàbado, the fuel tank was emptied, attended the gas station to put 4 gallons but before entering the fuel it put ¼ of boat (approximately 5 onz) of the injector cleaner, previously he had already thrown him and had no problems, the car turned very well, as at 7 minutes of moving forward, he began to that turns off.
5.- Yesterday, Sunday, disarm the rear seat to check the pump, it did not know that the fuel filter was the same, below the rear seat, when disconnected the filter I realized that the majority of the injector cleaner was there and that at the same time the filter was resurrected since it came out as mud, I tested with the pump, the pump has enough pressure, I changed the filter, I changed the filter Tube/camera that is before the injectors, there was quite a lot of fuel and evidently verified that the fuel arrived very well I did this several times as threw or cleaned the fuel drainage, remove the injectors I have made tests, it effectively comes out of each injector, the car does not yet turn on.
Check the spark plug cables, the current has a very good time, I know the spark plugs are sparks, as I put them, with the same calibration and they spark
6.- I put the scanner and I do not give me any error, the strange thing is that not even the one that I have commonly had that is the oxygen sensor.
7.- Two months ago I changed the original time band, I was very good, the check is in perfect condition.
The car I have not managed to turn it on, which can be ??????????
