Perkins 4 motor
13 years 3 months before #37139 by manual-mecanica
Perkins 4 Motor Published by Manual-Mecanica
Hello if someone can help me I have a perkins four and I do not get the injectors the engine was stopped for 10 years I put gas oil and I started and I started the fuel tank with all the new pipe and I could not make it start more if someone can help me I will appreciate it
13 years 3 months before #37145 by manual-mecanica
Manual-Mecanica Answer on the Perkins 4 motor
You might have the input and output pipes of the entrance to the entry into the return luck
13 years 3 months before #37146 by manual-mecanica
Not not because I took it out of the combutible tank and put it in an drum to the hoses
13 years 3 months before - 13 years 3 months before #37149 by manual-mecanica
Pressure problems will not?
Does the pump do well?
Latest edition: 13 years 3 months before by .
13 years 3 months before #37156 by manual-mecanica
Yes because I start the truck when I throw it but now stop it and do not start again
