Problem with Nissa Platina 2006
13 years 3 months before #36888 by manual-mecanica
Problem with Nissa Platina 2006 published by Manual-Mecanica
Good afternoon, first greeting them since I am new in this world of mechanics ... but I have a thousand doubts with my car and I really do not want to get green and that the mechanic tells me things that I do not understand.
The problem is as follows, the car runs begins to force the engine and the revolutions get crazy, and the car gets heavy, the temperature rises and then I have to turn off the car so that it does not hot, after a while I turn it on and as if nothing, but it only happens since I go to long distances, and to fix the thermostat and I made change of oil, but I do not miss other things I do not know if with the tuning. Major, it is a 2006 Platina Automatic transmission
I hope you can help me,
in advance thanks.: Laugh:
13 years 3 months before #36890 by manual-mecanica
Manual-Mecanica response on the problem with Nissa Platina 2006
Check that the radiator fan funeral when the temperature reaches its original state that is between 80 and 90 degrees centigrados and that the water level is the indicated since your failure is due to temperature eccess and when that passes that the
engine
is
dew Temperaure sensor (very rare)
so some among other
luck
