Correct Light Ford Explore
13 years 3 months before #36871 by manual-mecanica
Correct Light Ford Explore Published by Manual-Mecanica
Friends from the city of Santiago I ask for help I want to convert my Ford explores gas I need information how I can correct the ignition because the gas explosion is not the same as gasoline. If someone has any idea of ​​how to see that process, I also need to emulate the signal of the injectors but that information was sent to me
any information will be grateful.
Greetings Antonio .....;)
13 years 3 months before #36875 by manual-mecanica
Manual-Mecanica Answer on the topic Correct Light Ford Explore
Good
look at the ignition is the same for a gas truck that with gasoline if you have a coil bank you can not modify it and if you have a distributor you can attract the time about 15 or 20 degrees with stroscopic lamp but the ignition you have with gasoline can serve you
13 years 3 months before #36877 by manual-mecanica
MFPRSKA.
GRASIAS FRIEND ARE SUVA AND I COME YOU
